1 - 20 of 463 Posts
Ecoboost MODS & Maint
I am getting ready to do the first oil change in my truck, that I bought used a few months back
Now at 22,000 miles (dealer did syn oil/filter at 17k), I am also going to swap in new plugs
I ordered a set of Motorcraft Iridium (SP-534) plugs from Rock Auto
Crazy cheap compared to everyone else, like $4.02 each
These are the plugs all dealerships are using for Eco rough idle and hesitation reports
With a 5% off order coupon code, its a cheap plug change
I am going with a .030 gap, because from what I read this is what the SP534 come pre-gapped to....
I have read alot about some drilling a 1/16" hole in the intercooler, the help drain out all the moisture........ Anyone do this???
Mechanics intuition says hell no. But curious if people are actually doing this. You would think proper operation would get rid of water in any intercooler.
Discussion Starter #3
Search for 3.5 Ecoboost CAC on YouTube
It's crazy how much water runs out after the hole is drilled
Discussion Starter #4
http://www.f150forum.com/f70/video-drain-hole-ecoboost-cac-cooler-ecoboost-f-150-drain-hole-seep-243449/
http://blog.bluespringsfordparts.com/245/ecoboost-shudder/
Discussion Starter #6
Jeepermat:34412482 said:
I am not an ecoboost expert, nor have I ever seen a maintenance chart for one, so take this for what it is worth...
Why change the plugs? I have 2 vehicles with over 200k that are on their original plugs, I went to change them at 175k and they looked like new. Plugs last forever these days.
I pulled one, and it was worn badly and gapped at nearly .042
Twin turbos must eat these...... Most are being replaced at 20,000 miles
:laughing::laughing: Right. :shaking:
why meter air and leak it out a hole? I could understand putting a small condensation trap with a ball valve which gets opened every couple of days but don't just drill a hole.
Seriously, my Moms GM 6.0 has over 200k on it with the original plugs, Ive got a set in my garage for it, however there is no need to replace them as they look and gap to new specs.
Regardless of application if you are removing the plugs for ANY reason, you may as well replace them. They are cheap insurance. Just the act of removing them may damage them.
And you have already performed the labor of removing them, so replace them.
Not to mention the factory spec's intervals. Even your 6.0 should have a factory spec'd spark plug change at 80-100k
Most DOHC V6's spark plugs are typically 60k or so.
And before you say "they are still fine at 200+K miles" again...
They are not.
The rig may run "fine" but it isnt running as designed.
I have a 2011 EcoBoost, I changed my plugs at 20k, and it smoothed out the idle. . I have not drilled the.050 hole in the tube. But I'm in North Texas is usually pretty dry here. I just had mine in for a warranty repair for the clogged catalytic converter p430 code, and they replaced the cat and reflashed the computer. Runs leaner now and my mpg went up to 19mpg mixed, up from about mix 16mpg for the first 3 years.
Discussion Starter #12
Thanks....... Did you use the SP534 plugs?
They are not.
Im curious what on the plug is worn out? They gap to new specs, the electrode has not appeared to wear at all.
Unpossible. Someone has put plugs in it, or you are measuring wrong. OE plugs in LS motors don't wear as quickly as some others, but at 120-130k they have noticable wear.
Discussion Starter #15
I was messing around today and was surprised how dirty the drop in air filter was, after 5,000 miles
It was nasty, I was ashamed
Are the twin turbos sucking in that much air, I have seen some 10,000 mile old filters that weren't this dirty
It depends on where you drive and the air cleaner's inlet location.
It's rare for me to find myself replacing air filters due to clogging up/loaded of dirt, either.
Discussion Starter #19 (Edited)
I went with the Purolator PureONE Air Filter PA35642.......same filter as the 6.2 Raptor
Height: 2.57"
Length: 10.5"
The MotorCraft #FA1883 is what I am currently using, but the pleats are not deep, at all
Height: 1.730"
Length: 10.470"
Agreed. I just did mine in my 04 6.0 at 135K miles and they looked original and were very noticeably worn, and it idled like shit. Plus, on mine they changed the gap spec from .060 to .040 because if you run them to 100K (or beyond) the gap gets unreasonably big. I put NGK Iridiums in and they run great.
1 - 20 of 463 Posts
