1 - 1 of 1 Posts
excursion tank in an 06 350, gooseneck Qs
Looking for some insight on this. Trying to mount the excursion tank in the rear of my 06 F350. Getting rid of the stock braces as they are holding it from going up 6".
For the rear I will use a piece of C channel right near the back of the frame and have a bolt go thru that and the hitch.
Not sure what to do with the front crossmember. No real room to put a C channel there, unless i put one directly over the rear axle where the frame goes up and narrows in a little bit to 36" wide.
Or should I get a flat plate gooseneck hitch and just bolt that thing to the frame? My concern with this is the bottom part of the C channel frame is unconstrained.
Any insight is appreciated.
1 - 1 of 1 Posts
