I just finished installing an efi system in my 73 Bronco. I went to start it up and it started but it wouldn't idle correctly. It would only idle at 2300 to 2800 rpm. I played around with the idle air bypass sensor. I even changed it for another one that I had in the shop. No change. Then I changed my throttle body. I had a modified TB on that I bored out and made a new flapper for so I thought maybe that’s the problem. I changed it back to a stock TB. This helped. Now it wants to idle, but now it idles very rough if it idles at all. I then pulled the plug on the distributor that allows me to set the timing this helped, but it still surges while trying to idle. I have not run a diagnostics test.
The other twist is that the motor it is on is a stroked 393 with a lightning lower intake Gt-40 upper 24# injectors 70 mm mass air calibrated to the injectors.
The computer is stock to 91 Gt A9L.
Is this my biggest problem?
Thanks for any help.
