Okay,
Up until a couple of days ago, I was going to go with a complete battery management system.
Now, after looking at various websites, and this post Winch Wiring Options, I decided to go with a marine dual battery switch, by Guest.
I have purchased the switch, and it is wired into my system, presently.
It's wired as follows:
Feed = Alternator charge wire, starter cable, and wire feeding primary electrical in the Jeep.
Battery One = First Optima Yellow Top
Battery Two = Second Optima Yellow Top
Field disconnect = Not used, I am using an internally regulated 'Chevy type' alternator.
My questions are ...
If both batteries are connected to the system (using the "both" position on the switch), will they be charged equally?
Should I install a separate isolator, to assist here? Or would it do any good?
I can't help but wonder if, the alternator will 'sense' the higher charged battery, and stop charging.
I appreciate all responses,
