I think the spindle is around 30-35 ft lbs, but I can't find those specs...Originally posted by BossGrip:
<STRONG>Bearing cap nuts are 60 ft lbs.....ring gear bolts are 55 ft lbs.
Back lash....6-10 .000
New pinion bearing preload 12-15 .000
Used........................6-8 .000</STRONG>
Is this pinion bearing preload with the seal in place and applicable to a dana 35?BossGrip said:Bearing cap nuts are 60 ft lbs.....ring gear bolts are 55 ft lbs.
