1 - 9 of 9 Posts
· In GOD we trust. USA
The Rockslut said:
Cooler oil is always good, but you better plan on running a filter somewhere between the cooler and the block off.
If you have never ran a cooler off of the filter mount then where have you ran an engine oil cooler from?
Actually, I've run a tranny cooler. I've never run an engine oil cooler....what I'm wondering about is the adaptor cause any unusaul problems, leaks?
I run a block off with a relocated filter and converted a cheap tranny cooler to an oil cooler. It saved me about 20-30 degrees of engine operating temp and got me 1.5 qts. extra oil capacity.
I used to run the style of block off that you have pictured and had noting but problems with it sealing. I later switched to an 45* angle adapter from Canton Racing Products and have had zero sealing problems and it is a much niocer unit.
Canton also makes a TON of cool oil supply and motor goodies.
Stuff looks good. What is the part number for the 45*.....wasn't able to find it. Thanks for the link.
1 - 9 of 9 Posts
