1 - 2 of 2 Posts
I have a willy's flatfender glass tub mounted on a 74 cj-5 frame that I am working on. I got a 225 v6 from a commando and cut the motor mounts out of it to weld in the cj5 frame but I am not exactly sure where I what to mount them, I heard I should offset it 1" to the drivers side and have a 2 degree angle, is that right? Would anyone happen to have pics of their mounts? Thanks, Matt
Well I'd put it in the middle. When I dropped the engine in my TJ I faced the same issues, not knowing where it should go. 2 deg angle isn't very much, that would hard to get right if you were trying to do it. I'd say the damn rubber mounts may even flex that much.
But I may not have any idea what I'm tlaking aobut with your setup.
Hopefully someone who has done it can chime in.
Goodluck
Nick
1 - 2 of 2 Posts
