1 - 8 of 8 Posts
i have a1991 toyota pickup and im replacing the old 22re with a blown rod with a used 1994 22re from a 2wd. When bolting the tranny up to the motor everything was lined up perfect. So perfect that at the top of the tranny housing and the motor connection plate in between the top two mounting bolts there like a nub which i assume is to line up the tranny and motor. But my problem is that there was one on both the transmission and the motor in the exact same place. So had to take the motor out and figure out what to do now. Any help or explanation would be greatly appreciated. Thanks
i got the engine in and they are sitting perfectly on the mounts, but only the top part of the tranny is tight. While as you go down the tranny it opens up to about 3/4's of an inch. i tried jacking the tranny up and down also the lifting the engine up and down. Any suggestions or tricks you guys know of would be awesome thanks.
1 - 8 of 8 Posts
