1 - 18 of 18 Posts
Found this on the net...Not sure if it is a repost but here are a bunch of engine wieghts.
4 CYLINDER WEIGHT(LBS.) LENGTH(IN.)
VW Type one 200 14.5
VW Type four 280 22
VW Rabbit 230 19
Chrysler 2.2 & 2.5L 267 21
Ford 2.0L Pinto 286 15.5
Ford 2.3L Pinto 328 24.5
GM 2.5L 285 22.5
GM Quad 4 2.3L 320 21
Saturn 1.9L DOHC 240 19.5
Subaru 1.8L ('81-'86) 188 14
Subaru 1.8L OHC 200 16
Subaru 2.2L ('90-'96) 260 16.5
Subaru 2.2L Turbo 265 16.5
Subaru 2.5L 270 16.5
Toyota 4-A 1.6L-16V 225 20
Toy 3SG 2.0L-16V 293 22
Toyota 18R-20R-22R 315 24.5
6 CYLINDER WEIGHT(LBS.) LENGTH(IN.)
Acura 2.5 & 2.7L 350 20.5
Acura NSX 275 20.5
Buick 225 & 231cu.in. 390 22.5
Buick 3.0 & 3.3L 377 23
Buick 3.8L, '85 & up 380 22.5
Chevy 2.8 & 3.1L 350 24
Chevy 4.3L 420 25
Corvair 300 24
Ford 2.6-4.0L 365 23
Ford 231cu.in. 402 21
Ford 3.0L 380 22
Ford DOHC 2.5L 390 19
Ford DOHC 3.0L 447 22
Mazda DOHC 2.5L 390 19
Mitsubishi 3.0L-24V 365 21
Mitsubishi 3.0L Turbo 370 21
Nissan 3.0L 360 20.5
Nissan 3.0L Turbo 365 20.5
Porsche "911" 3.3L 280 23
Subaru 3.3L SVX 387 21
Toyota 3.0L 360 21.5
Volvo 350 21
VW 2.8L('92-'94) 374 19
8 CYLINDER WEIGHT(LBS.) LENGTH(IN.)
Buick 215cu.in. 320 28.5
Chevy small block 500 29
Ford small block 450 29.5
Rover Aluminum V8 320 28.5
Misc WEIGHT(LBS.) LENGTH(IN.)
Mazda rotary 12A/13B 260 20
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
It would take a sick individule to run one of these two in a trail rig.
NoRM ;-P
thhhpptthh!
Is the 4.3L weight listed there the vortec? I thought the Vortec was lighter...Did they specify how complete the engine was a weigh-in (i.e. accessories, smog gear, injected or carb'd) or if was block weight only ?
Cool list...
Kevin
Re: Re: Engine Wieghts
NoRM ;-P
Who runs a Mazda Rotary? I know there was a buggy way back when that had one, but I onyl ever saw one pic of it and I don't think it ever made it to a comp.
J. J.
I've contemplated running a rotary several times since I have one sitting in my garage. They've got a lot of goods and one major bad.
Goods:
Small, completely assembled they would fit in the tranny tunnel of most trucks
Relatively light, I think that figure is a bit high, or is for a complete motor, because I can pick mine up and over a fender fairly easily and I'm not a big guy
Power, in stock form they're good for 200hp, and with a turbo they run 250. Also easily buildable to upwards of 700hp.
Bad:
they are VERY rev happy. They can be modified to RPMs of over 10k. All of their power is high up, with no major off the line torque. My Uncle is putting one into his MGB, which is a good lightweight application for this motor. However, I think in a buggy you would find it too rev happy.
One more thing, you'd have to adapt a tranny to it, or use a divorced case. Although the stock Mazda turbo tranny is pretty bulletproof. HTH
Ary
I was working on an Audi A6 this last week, with a V-6, 5 valves per cylinder, anyone know anything about this engine, it was a 99 A6. It was aluminium block and heads, felt like it had good power..
Ryan
ANyone know the weight of a 4.0 toyota/lexus V-8? Its 32 valve and makes 250-300hp, and 260-290lb/ft torque (I think the torque is great for a small motor)
Re: Re: Re: Engine Wieghts
J. J.
Russ Hogan from I think Disney OK. , run a rotary engine in his buggy and competed in a few Prorock events in 2002. That thing would turn some insane amount of rpm's , then fill the whole comp area with smoke .
Rover V8, 320lbs... hey I'm putting one of those in my rig :D Mine is a 1989 3.9L EFI version and makes about 185hp and 260ft lbs stock... But of course I'm going to play with it a little and go for 220hp and 300 ft lbs ;) (easily achievable)
Before getting too hung up on weight alone, consider the weights location.
A motor that has a wide base like a VW sometimes is a pain when it comes to control arms vs. a FWD 3.8l gm which is very narrow in the block but has a lot more weight up high.
As you can tell, I've found a few problems putting the new buggy together.
Also after driving the VW again vs the 3.8L, I remember again why it was I said I needed all that power.
Horse power at idle should be a major concern for rock crawling. That's the easy way around the course.
With that in mind, let me say for the record......LS1 or nothing.
tony k
Now Scott is not the only one, I have one I am putting in a buggy. I was going to run a honda but this just worked out better. Now I am just worried about lack of power.
1 - 18 of 18 Posts
