1 - 20 of 28 Posts
list of engines with GM bolt pattern (and specs) need help with data
Hey, a lot of holes in this spreadsheet, if you know something POST UP!! (then maybe we can sticky this)
Code:
Engines that have 60* GM Bolt Pattern
		idleTQ	maxTQ		maxHP		name & year
3.2 (6)	RWD		[email protected]	[email protected]	(93-97) isuzu SOHC / MPFI
3.2 (6)	RWD		[email protected]	[email protected]	(98-02) Isuzu DOHC / MPFI
3.5 (6)	RWD		[email protected]	[email protected]	(98-02) Isuzu DOHC / MPFI
3.5 (6)	RWD		[email protected]	[email protected]	(04) Isuzu DOHC / DI
2.8 (6)	RWD		150		125		(89-92) GM pushrod / TBI (Isuzu Trooper)
2.8 (6)	FWD		160		130		(87-94) GM Gen II Pushrod / MPFI
2.8 (6)	RWD		195		210		(05-) Cadillac CTS DOHC / MPFI
3.1 (6)	RWD				140		(89-92) GM pushrod / TBI (Isuzu Pickup & Rodeo)
3.1 (6)	RWD		180		140		(90-) GM RWD pushrod / MPFI
3.1 (6)	FWD		180		140		(90-95) GM 3100 Gen II pushrod / MPFI
3.1 (6)	FWD		195		175		(93-) GM 3100 Gen III Pushrod / MPFI
3.4 (6)	RWD		180		160		(93-95) Camaro V6 pushrod / MPFI
3.4 (6)	FWD		205		185		(96-) GM 3400 pushrod / MPFI
3.4 (6)	FWD		215		210		(91-97) GM DOHC / MPFI
3.4 (6)	RWD		194		160		(99-) GM HT crate pushrod
3.5 (6)	FWD		220		200		(04-) GM Malibu 3500 FWD Pushrod / MPFI
3.6 (6)	FWD		235		245		(04-) GM Global DOHC / MPFI
3.6 (6)	RWD		252		255		(04-) GM Global DOHC / MPFI
3.8 (6)			235		200		GM 3800 Pushrod / MPFI
3.8 (6)			280		240		(-03) GM 3800SC Pushrod / MPFI
3.8 (6)			280		260		(04-) GM 3800SC Pushrod / MPFI
4.0 (8)		[email protected]	[email protected]	[email protected]	(95-01) Olds Aurora DOHC / MPFI
4.6 (8)		[email protected]	[email protected]	275		(-94) Cadillac Northstar L37 DOHC / MPFI
4.6 (8)		[email protected]	[email protected]	300		(95-) Cadillac Northstar L37 DOHC / MPFI
4.9 (8)			280-300		200		Cadillac V8 Pushrod / MPFI
perhaps you should post this into the FAQ thread that is already sticky'ed?
-Rob
Yeah, I'll post a link there. Or maybe put the whole thing there when it has enough info. It just seems like people's additions would muddy up the content of the Faq thread.
Yeah, I could only wish that Aurora 4 liter, or the northstar 4.6 would bolt up to my 4l30......life would be better...
Chase
houlster said:
So, what are you asking? What bolts to an MUA-5, or what Isuzu used engines have a GM bellhousing pattern?
--Dan
List of engines that can bolt to a first gen isuzu tranny with gm bolt pattern. Maybe, common isuzu engine swaps, including some others just for a baseline. I added others just because it seems like people often ask -- might as well put all of them in the same place. let me know if you think this should have a different title, or if you think this would be useful.
No, it was just the 2.6 in the list of engines with the GM pattern that threw me.
Maybe add a column with what bellhousing pattern(s) the motors use. The 3.2/3.5 are dual pattern as well.
To add:
3800SC 240hp, 280 tq. '04 & up are 260 hp., same tq.
4.9 caddy V8. 200 hp, 280-300 tq depending on who you talk to.
GM 3.4 DOHC v6 210 hp, 215 tq
--Dan
So did I read this wrong? Or are the 3.2(early SOHC), dual bolt pattern trans?
Like, the Northstar will bolt up????????
I know they are 60* bolt pattern....but...
Chase
Chase
Don't get too excited yet. I'm just putting together a list, so I rely upon other people's input. Some stuff may be wrong, get me? If something's wrong let me know and I'll change it.
In the meantime, i'll remove the early 3.2 bolt pattern until someone tells me what it is.
well, damn... Its would be nice to know... I know for a fact the NStar will work on a 60*...but I havent removed the motor or tranny in a SOHC motor..so Idont know the bolt pattern... but if it will work.....
Chase
Chase
Um, didn't I just answer that a few posts up? Yes, the early 3.2 and the DOHC 3.2/3.5 all have a dual bellhousing pattern. One of them is the GM 60 degree v6 pattern. Yes, the 4L30-E uses that pattern and a Northstar or any other motor with the 60 deg bell will bolt to it.
Torque converter/flexplate issues may need to be worked out depending on the combo.
--Dan
Just wanted to be sure.....
I am more than happy now....
Chase
The first engine on the list, the 3.2 SOHC, should be the DOHC. The '93-97 DOHC is the one that makes 190 HP, while the SOHC just...well...it leaves you wanting to swap.
Sure, it's splitting hairs, but that's what I do. :D
I guess some BMW engines would go onto the 4l30e, but that would be :rainbow:
1 - 20 of 28 Posts
