1 - 20 of 28 Posts
Vendor
ENGO USA has a winch for every need. With over 30 years of specialized experience, we know what it means to create a quality product that gets the job done. Our winches have world class features, innovative designs and the best warranty on the market.
Whether you need hydraulic winches, electric winches, truck winches, ATV winches, boat winches or winch mounts, we’ve got you covered.
By keeping you – the customer – at the heart of our business, we’ve developed a reputation for providing the right winch at the right price. In fact, ENGO Winch was named the best value in a recent Four Wheeler Magazine winch shootout!
Our global manufacturing facilities help us maintain our top quality performance, first class design and unbeatable warranty. From hydraulic winches to electric winches, our expanding winch selection has just the model and size that you need.
We’re ready to meet your off-road 4X4 truck, boat or ATV winch needs.
Model E 9000
Rated Line Pull 9,000 lb. (4090kg)
Motor 5.5 HP, Series Wound
Gearing 3-Stage Planetary
Gear Ratio 235:1
Brake Automatic Load Holding
Clutch Free Spooling
Fairlead Heavy Duty Roller
Cable or Rope Wire 21/64" x 92' (8.3mm x 28m)
Net Weight 85 lb. (38kg)
Dimensions Length x Width x Height, 21.9" x 6.3" x 8.7" (555mm x 161mm x 222mm)
Drum Dimensions Diameter 2.5" (63mm) x Length 8.8" (224mm)
Mounting Bolt Pattern 10" x 4.5" (254mm x 114.3mm)
Warranty Limited Lifetime / 1-Year Electrical
Call 706-207-4140 to order!
Vendor
Discussion Starter #2
Model E9000S
Rated Line Pull 9,000lb. (4090kg)
Gear Ratio 235:1
Fairlead Hawse
Rope Synthetic 3/8" x 85'
Net Weight 60 lb. (27kg)
Dimensions Length x Width x Height, 21.9" x 6.3" x 8.7" (555mm x 161mm 222mm)
Vendor
Discussion Starter #3
Model E 10,000
Rated Line Pull 10,000 lb. (4545kg)
Motor 5.6 HP, Series Wound
Gear Ratio 265:1
Cable or Rope Wire 23/64" x 85' (9.1mm x 26m)
Net Weight 88 lb. (39kg)
Vendor
Discussion Starter #15 (Edited)
Engo makes a quality winch at an excellent price! We've installed these on several Jeeps and had great luck with them. The 10,000 is great for the 4 door JK's! The 9,000 is excellent for a TJ, YJ, CJ, or 2 door JK.
They have an awesome Carbon Fiber coating now too! and it looks killer!
Thanks,
CCOR
706-207-4140
1 - 20 of 28 Posts
