1 - 3 of 3 Posts
im installing a 727 and dana 300 into my cj7. Im wondering if the soa with stock yj springs is going to be high enough to make room for my drivelines.?? anybody ever done this?
Ummm what?! :confused:
Not sure what you are asking or trying to ask but first of all search, I know theres been enough info on similar projects just by use the process of deduction that....
Physically the 727 and Dana 300 will fit fine.
Your driveshafts may or may not have to be modified if you aren't running a CV shaft in the rear
If you aren't running a CV shaft in the rear then you will need to buy one
Getting your pinion angles correct will eliminate driveline vibtrations.
good deal
good deal thanks. Yea I have been doing a little research before i posted the thread and it was saying I'll need atleast a 4-6 inch lift to do this combo in the cj7 because the front driveline would hit the tranny and oil pan if not. Thanks for the 411!
1 - 3 of 3 Posts
