1 - 11 of 11 Posts
does look nice only thing id add is maybe a spreader in the rear section.. it he flops on the assit looks like it may fold in pretty easy.. just my 2 cents..
does look good.. lets hear the rest of the specs..
payton
I like the front, looks beastly. I have been thinking about intagrating a halo into the edge of the roof to keep it from colapsing. Then glass breakage is the bigest problem, speedglass is the anwser :D.
Fenders
Are the tube fenders tied to the body or just to the tailing edge of the bumpers and the rockers...
If they are not tied to the body I would recommend adding struts between the hood hoop and the fenders - same in the rear (plus tie it to the uni-frame to make it bomb proof!)....
Lest you suffer this fate:
This was a stump that hooked the front edge of the fender on Dan Starc's rig
Mine are like this and I have had the whole weight of the rig - (2 tires in the air) on these fenders and just picked up some gouges in the steel - no dents:
Also in the back of your cage I would triangulate across the opening or at least add a tailgate type strut... Unfortunately that location is the weakest area on mine too - if you make that area strong you have pretty much lost any functional value for storage or access :( - Damn fiberglass structural hatch... :rolleyes:
If the cage is not tied to the body it WILL shift during a roll... :flipoff2:
Matt
Discussion Starter · #11 ·
We talked about adding such a bar. The owner was still undecided when he picked up the rig, but I think he will add one.
The tubing is 1 3/4".120 electric weld. Look's like the tubing that bent on that tan-grey? cherokee is thinner wall.
Specs... 4.3 Chevy, 700R4, NP231, Dana 60s
1 - 11 of 11 Posts
