1 - 13 of 13 Posts
So on my 4bolt 350 out of a 1980 1 ton truck I will be running blockhugger headers with single 2.5" exhaust. So I'm wondering what muffler would work best. I'd like a 3 chamber so it's not too loud unless I get on it, and I'm not a fan of Flowmaster cuz everyone runs that.
So what do you all think would be a good muffler with decent backpressure for my rig?? I'll spend up to $100 on it, not including install, etc..
What do you run and how do you like/what don't you like about your own setup?
Thanks
Everyone runs Flowmasters because they are the best muffler for the money. Barring them altogether, I have to agree with Borla. Hooker also makes an okay muffler, but since it appears budget is not a concern, I would be leaning toward the Borlas.
cherry bombs are the only way to go. JUST JOKIN'
I would go with a 3 chamber flow, they sound the best, they dont backfire down hills,and will not ever blow out.
Discussion Starter · #9 ·
What about MAC mufflers?
In a mustang mag they pr oduced the most power on a stang, but were also the loudest.
What is the difference between the mufflers we've been talking about and "turbo" mufflers?
Summit sells them for like $30 each. How are they different than Flos.
What could I get that would be as quality as the flos as far as fully welded and thick guage, but a diff. brand cuz flo are so overused, every grocery go getter and soccer mom suburban around here runs them.
I have a 3" in 2 21/4" out flo but that's too much hoo haw for only single exhaust (running the twice pipes just for looks). If anyone wants it let me know.
3 big problems with flows. 1. the bafles will eventualy rust out inside and come apart. 2. they are pretty restrictive. I would get hooker aerochambers if I were you. they are cheaper, the baffles are stainless steel, they sound better (at least, IMO) and they aren't loud at idle.
i like how flows are built but i hate how they sound.
so i run hooker super comps. they sound good to me and they are well built.
if you're on a budget then definatley the thrush turbos. they work well for the money.(13bucks at summit last i checked)
why are you going with 2.5 inch with a small block? isn't that kind of big? are you running some pumping some serious HP out of that bad boy?
if you want to get the best exhaust system i highley recomend:
Dr. Gas, Inc
1672 E. 10770 SO.
Sandy, Ut. 84092
801-571-6097
they make some sweet "X" cross over set ups.
i ran one with my pumped 454 in an old truck of mine and i kick arse.
Discussion Starter · #13 ·
The small block is bone stock except for a weiand intake and edelbrock carb and soon headers, so basically stock. I'd say at the most it has 200hp...on a good day
I thought that 2.5" single exhaust would be right,
Differing opinions/thoughts on this size for exhaust tubing???
1 - 13 of 13 Posts
