1 - 10 of 10 Posts
who has done this?..I did a search and only found one person..wonderin if anyone has done this since..
this is what I made..give me your opinions..
I took a piece of 2" and wraped it with 25'of 3/8 copper tubing,then I took a piece of 3" and put it over that..so the copper is completely encased in between the 2" and the 3"..I planing on putting it after the cat but before the muffler...so far I have about 18 dollars into this...so...what do you guys think?
I assume you plan to heat water? It is normally done by routing coolant from the heater hose through the exchanger. I don't believe what you have come up with will be as efficient....Especially at idle. Good luck. <IMG SRC="smilies/rolleyes.gif" border="0">
IH/Rover Moderator
Wheeldog there are a few that have done that way and it works better! The exhaust gets hot in about 60 seconds and the water in the cooling system about 10-15 minutes. The exhaust is +300F and the water only 180F! It works much better! So I guess the cold shower is on you! <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0">
thus the newbie status.hehe newbies are to been seen and not heard <IMG SRC="smilies/laughing.gif" border="0">
thanks for the "educated" replies....so is my setup similare to those you have seen work?I have heard it should be hot enough to need a cold water line also..thanks for the help
IH/Rover Moderator
You should run a shower mixer valve or you can get the water too hot. What are you using for a pump?
I'm using a 3 gpm RV pump..1/2 "inlet 3/8"hot..3/8 cold..1/2 "outlet to low flow shower head...I should be able to take about a 4 minute shower with 5 gallons of water(on full blast)
IH/Rover Moderator
The mixer can be a cheap 20.00 Home depot one or I'm going with a marine one.
<IMG width=293 height=288 SRC="http://www.pirate4x4.com/ubb/uploads/shower-compact.gif">
<IMG width=122 height=151 SRC="http://www.pirate4x4.com/ubb/uploads/shower-compact2.jpg">
<IMG width=120 height=173 SRC="http://www.pirate4x4.com/ubb/uploads/shower-rinse.jpg"> <IMG width=191 height=230 SRC="http://www.pirate4x4.com/ubb/uploads/shower.jpg">
All made by:
http://www.whalepumps.com/
[ 09-16-2001: Message edited by: Old Scout ]
1 - 10 of 10 Posts
