1 - 11 of 11 Posts
I am trying to design an exo cage for my scrambler. I want to tie my seats into this cage if possible. Does anyone have any suggestions or opinions about doing this. Is it even possible.
Anythings possible... but why - I have an exo on my cherokee because it has lots of glass and a metal roof that would come in on my head if I had no cage.... If I was starting again from scratch I would just chop the top...
Why not build a good internal cage with some tube fenders and a radiator hoop (tie it all into the frame and internal cage)
If you rub on the back end alot just run a hoop around the top edge of the tube kinda like rocker pro...
Your going to bob it anyhow right! :flipoff2:
Matt
do you thinnk that this will provide enough body protection also anyone in the North Carolina good at making cages. On an off topic i need a jeep box that will fit in my scrambler
Yeah i really like kristy's it is awesome especially the scout cage. If i build an internal i need to have a way to put on my half hard top unless someone can think of someway to make a cage that can protect me from the elements. I really need someone in nc who likes to work cheap
I'm planning on putting an internal cage in the XJ for MY protection, and do basically what ROKN ZJ is saying --> tie the front and rear bumpers into fender protection, and tie those into some nice rocker guards.
I have been thinking full exo, but that's a lot of tubing, and a lot of weight...
Essentially Off-Road sells in in-cab cage kit that allows you to use your half cab:
I have a similar cage in mine that was built to work with a YJ dash:
I like that XJ... You hardly notice the tubes... the "low-profile" (lower weight, too) design is pretty cool.
Here's a paint I did in another thread... also, check out Redrum's TJ.
1 - 11 of 11 Posts
