1 - 9 of 9 Posts
I did this one for my girlfriends mom. It is a cj5 stretched to 110" with a rear 4-link. Eventualy we will run tube for front fenders. The tube over the fenders ties into the B & C piller thru whats left of the comp cut tub. Without the top on thats realy all you need....
webdr said:
How did you handle the frame on that stretch? I am cutting my frame in front of the forward rear spring hanger and I cant decide whether to go box or double tube.
The frame was cut at the top of its arc, capped, then two tubes were extended to the rear bump stop. From there a single tube continues to the rear to hold the fuel cell, tire & tow points. The cage ties solidly into the frame.
This forward/rear spring hanger holds the front of the leaf spring.
Its a little dirty but you can see things in this pic.
1 - 9 of 9 Posts
