1 - 1 of 1 Posts
Anybody running a 78 and later 10 bolt tie rod on their Dana 44 knuckles?
This will give another inch or so of clearance over the regulaer Dana 44 tie rod.
I'm swapping mine, and everything measures up, but there's only one minor drawback: to get the tie rod to go on, you have to unbolt one spring from the axle and jack that side up for clearance. The first side goes in okay, but then you get snagged on the other side. Once you install, you can drop the truck back down and tighten the bolts.
Thought you rock crawlin guys might like this, if you hadn't discovered it already.
1 - 1 of 1 Posts
