You haven’t even done the SAS yet <IMG SRC="smilies/biggrin.gif" border="0"> ! J/K, remember droop will be great with longer shocks, but compression will be limited i.e.( wheel-well, bump-stops) unless of course you CUT. Also consider the d-shaft in the rear, too much droop may require a long spline shaft (extra$$). Are you thinking of keeping just leafs? Or maybe running coil-overs? What are you thinking? Is this a trail only rig? Are you thinking Baja type suspension?
