1 - 20 of 24 Posts
So I wasn't sure whether to post this here or on the tow rigs board, but here we go. I have a 2001 F250 SD that I put a 4" lift kit on. The kit is generic Pro Comp kit that has blocks in the rear and new springs up front. I torqued all the bolts as specified. When I am driving the truck I can hear and feel a squeaking noise coming from the front driver side of the truck when ever I make a turn. I have re-inspected ever thing under the truck and cannot figure out what is causing the noise. I have also replaced the front ball joints and had the truck alignment done. The noise and feeling has been getting a little more prominent lately. Does anyone have some suggestions?
My 08 started doing it after a 6" lift. It ended up being the driver side away bar bushing. I sprayed some wd40 in it and the noise went away.
Is the noise only when turning?
Can you jump up and down on the bumper and recreate the noise?
When you installed the lift, did you install larger tires and any aftermarket steering stabilizers? Can you feel it through the steering wheel? My power steering complained a lot when I put on 37s with an aftermarket dual stabilizer, but the noise went away after I removed the stock stabilizer. Too much pressure on the steering components? Just a thought.
Discussion Starter · #9 ·
The noise is the most prominent when turning but soemtimes can hear and feel it when I hit a large bump, it is always on the drivers side. I do have dual aftermarket steering stabalizers on the truck, but they were on prior to the lift kit. Currently it rides on 35" tires on stock rims.
Discussion Starter · #11 ·
Maybe I can add a bit more info as I drove the truck today. The I can feel the squeak or more of a grone directly under my feet. the grone is the worst when I turn the wheels when not moving. any more ideas?
Discussion Starter · #13 ·
if the unit bearing had gon bad on the driver side would I feel it through the floor board though? Because I can feel the creak and grone through the floor boards directly under my feet.
blatant asshole
if you can feel it when standing still and turning the steering wheel it is not the unit brg.
steering box, something rubbing the steering linkage, the springs shifting in the shackle/hanger, there is a tsb on the cab mounts.
2001 has leaf spring front. check this, I had my leaf springs twisting when I turned the wheel on my old FSJ. made a groan and pops when I turned the wheel sitting still. the leaf pack was twisting on itself.
1 - 20 of 24 Posts
