1 - 13 of 13 Posts
i picked up a 82 bronco with a 302 and C6 trans but i don't know what transfer case i should swap in, or if the 203 thats in there should be kept. i have a 231 sitting at home that i could swap in but i can find an adapter made by anyone (i only know of Novak and advanced adapters)
anyways 2nd question are the outer knuckles the same in a TTB d44 as the regular d44? are any parts interchangeable?
its a 208, with something like a 2.69 low range, run it till you break it as you will break other things before that things will bite the dust.
TTB and solid axle knuckles will NOT swap.
X2. Not even close. From the spindle out however will swap. Shity thing is the caliper mounting is garbage compared to the old style 44. IMO if you wanted to swap out you should be putting older 44 outers on the ttb. Not the other way around.
1 - 13 of 13 Posts
