Have any of you heard of a lift arm suspension, sometimes called a fifth coil suspension? I have seen it on stock cars, not NASCAR, but dirt and asphalt stock cars. There is a long torque arm that goes from the rear axle up to the CG, and a coil-over shock then transfers the torque to the chassis. I thought this would work well to reduce the shock to your chassis when the tires load and unload as you gain and loose traction while scaling a rock waterfall. As the coil spring compresses the anti-squat goes up.
Most of you will probably say, “Stick with what is tried and true” or “Sounds too complicated”
