1 - 20 of 216 Posts
Trail Tech Fab
Due to volume the new year brings reduced pricing and stud upgrades!
Front
Mounted
18 Degrees
36 Degrees
Studs/bolts are included. This allows the tcase to be clocked up 18 or 36(flat) degrees and will retain the input bearing as the stock adapter is designed to. All 8 bolt holes remain unlike some other clocking plates out there. An alignment ring is included to insure proper concentricity.
$145 shipped to your door. Custom configurations always welcomed. 3/8" thick to maximize spline engagement. New Fine thread studs maintain strength and eliminate the need for a thicker clocking ring, 1/2" rings still available by request.
As always, we work to have the strongest, most complete kits available. Don't be fooled with kits that don't include gaskets. These gaskets are critical and serve as "spacers" to properly retain the bearing in your 205. Running without these frequently leads to the cracking and failure of your cast iron transfer adapter.
Add a NP 205 rear support/torque mount for $60 now when combined with a clocking plate or Infinitely Clockable Adapter kit!
More info on the 205 mount can be found here.
http://www.pirate4x4.com/forum/showthread.php?t=1014481
Regards,
Mike
TTF
Trail Tech Fab
Discussion Starter #3
Do you have a clocking ring for the round 6 bolt pattern?
We don't stock 6 bolt rings for 205's, there would be a little lead time. Typically the bolt pattern is just redrilled in the 205 housing and the stock adapter is notched to allow for shifter clearance. The main advantage of the ring would be to prevent the need to redrill the housing, but the adapter still needs to be clearanced.
Trail Tech Fab
Discussion Starter #10
These are manufactured from 1/2" steel. I do have a couple made from 3/8", but I prefer the thicker version for better thread engagement.
Trail Tech Fab
Discussion Starter #11
We are now producing these from 3/8" steel and using studs to maintain strength. Spline engagement is maximized. As always, custom configurations are welcomed.
Thanks for the orders guys. Keep the feed back coming!
Trail Tech Fab
Discussion Starter #18
We use Paypal for our transactions. PM us your email address, which transmission you are running, and any special needs and we'll get an invoice sent to you.
Thanks,
Mike
Trail Tech Fab
Discussion Starter #20
1 - 20 of 216 Posts
