LOTS OF PIX
My brother, Erick561, just picked up this 1st gen. its a 79 cab with (1)or(2)88k on it running with an 87 22r, stage 2 cam and webber carbs, an 85 frame, and an 83 bed. decently tight truck. he paid way to much for it.. but.. you cant fix it if you dont have it right? those may be famous last words, but there is no way around these parts we could find another one in 1/2 as good in shape.
Ive been a web wheeler since i joined, reading everthing that intrested me and learning more than i ever thought possible, but I don't even have a 4x4 to do anything with! my brother saw a foreign imported toyota diesel retired from a military base on ebay and has been hooked on yotas since. now im finally in!
it looks like it has about a 2" body lift which is coming straight out before it gets back on the road. it has longer shackles and aals. axles are geared 488 with 32 tsls. this first pic was taken before it sat for 11 months, so picture it a little more rusty and not so shiny. you will see.
Plans; in order of most important:
-backhalf of frame is.. well.. what do you think... its gonna be a doozie
-new bigger radiator
-clean everything
-fix the heat
-take out stupid bolt together autozone cage in cab
-bed... what to do..
-ditch the little aals so the susp flexes
-rears up front, junkyard rears
-clean everything
-fix the heat
