1 - 4 of 4 Posts
i have a 91 1500 and the idler arm sux hardcore! it was replaced 6 months ago, and its already going bad. i read somewhere that you can get an upgrade kit for it. whats the best one? is there something elts wrong?
I do beleive that a 3/4 ton shaft will fit. someone will have to back me up on this. I know it can be swapped out on an S10.
The upgrade os to switch to a newer style 3 bolt idler. Try 95 and up. You will have to drill for the extra bolt and the unit is much stronger. Over 100k on mine.
Discussion Starter #4
Originally posted by John M:
<STRONG>The upgrade os to switch to a newer style 3 bolt idler. Try 95 and up. You will have to drill for the extra bolt and the unit is much stronger. Over 100k on mine.</STRONG>
where did you get it, and how much? was it easy to install, what problems showld i expect?
1 - 4 of 4 Posts
