1 - 4 of 4 Posts
The 02 liberty is throwing the P0122 code, throttle position sensor. Of course it needs to smog now and I'm wondering if I replace the sensor if the code will be gone and I can pass smog??
The dealership has the part for $50 that I can pick up today.
Just wondering if anyone had any other advice to offer so I can get this POS smog ed.
Thanks
Yea, just because it throws a TPS code doesn't mean that is the problem. Although it usually ends up being the problem.
O2 codes on the other hand are usually not the result of a bad O2 sensor.
well so far after replacing the TPS the check engine light isn't coming back on and the code seems to be gone.
*crossing fingers* this lets it pass smog.
thanks for the info guys
1 - 4 of 4 Posts
