FJ 60 box install
8.3K views 37 replies 11 participants last post by  godzuki
#1 ·
I thought I'd throw up some pics of the new steering setup I've been working on. With the axle now 6.5 inches forward of stock, getting decent tie rod/draglink geometrywith the Celica box wasnt possible.
The forward facing pitman on this setup has worked out really well as far as geometry. The overall size and shape of the box makes for a perfect fit.
As soon as I get my welder out of the shop (it died) and a flat pitman I'll finish it up.
#3 · (Edited)
The front sleeves came through right inbetween the walls of the radiator mount. I cut the front welds of the mount and bent it back so I can weld around the sleeves. Once the sleeves are welded up, I will bend it back and reattach the raditor mount.
#5 ·
The geometry of the draglink and tierod are perfect. The tierod actually clears the pitman, but the pitman will hit the spring when fully compressed. I need a flat pitman, hopefully Sky is going to make some soon.
#8 ·
With the axle this far forward and the way I built my extension the only Saginaw box that would work is the Scout II box. I had an IH before my zuk and can go the rest of my life without ever using IH parts again.
The IH box is essentially the same, just a huge version of the FJ 60 box. I think the FJ fits better, and being a jap part it will hopefully keep the fluid on the inside.
#9 · (Edited)
WOW really appreciate your detailed pics since I was just about to post a topic looking for pics. of FJ 60 boxes installed in Zooks.
So the pitman arm is a problem then huh?
The IFS arm won't fit on this box?
What about a pitman arm from a 2wd Yota steer box? These are about flat & have a female conical end on them already.
You don't think you'll have any issues with the arm hitting the drag link under full compression of the driver's side?
Is that the FJ60 steering u-joint onto a FJ shaft mated to the Samurai steering shaft??? Nice clean rig! Looks like a showroom model;)
Sorry about all the questions but inquiring minds want to know;)
#11 ·
Barely...if my shackles were in the front, or if I had lifted springs it would probably work.
It does fit, but it doesnt really help. The radical drop of the 60 arm way at the end makes more room than the gradual slope of the IFS arm.
Don't know about these.
Nope there is a ton of clearance, way more than I had before.
The u-joint is off of a Supra on a severely shortend Sami shaft.
BTW-a $100 is a great price!
#13 ·
Looks good scwafish. That is a clean setup. The FJ60 box fits better than the IFS box. Man you weren't kiddin about your Jethro hole-drillin jig, it worked awesome! Those holes are S-T-R-A-I-G-H-T ! I barely got my exit holes in the right zipcode. Keep me posted on the flat-arm search.
#17 ·
The real trick is the Jethro-jig process. It solves the age-old drilling straight through the frame issue. The process:
1) Make your plate and drill the pilot holes for the bolts. Double check the hole centers.
2) Clamp the plate to the frame and drill the ouside wall of the frame using the pilot holes in the plate for your template. The frame and the plate now have the exact same centers.
3)Drill the holes in the plate to the right size for the sleeves and counter sink the holes to improve weld contact.
4)Use the JJ to weld all 4 sleeves square to the plate.
5)Enlarge the pilot holes in the outside of the frame to the right size for the sleeves.
6)Push the plate/sleeve assembly into place until the sleeves bottom out on the far side of the frame
7)Use a bit the SAME size as the ID of the sleeves to drill a pilot hole in the far frame wall. The sleeves will put the far side center in the exact right spot.
8)Pull out the plate/sleeve assembly and enlarge the holes in the far wall to the correct size for the sleeves.
9)Put plate/sleeve assembly back into place and weld it up!
A finished "assembly"
#22 ·
Rockrat said:
Looks good Scwa where did you get those front bump stops I like:D
Take your pic:
http://www.suspension.com/Bumpstop.htm
I used the Cj ones from them on my Toy. $24 for the pair. The 2x2 box is just long enough to get full contact on the bumpstop.
Adding words for this to show in searches next time someone asks me about them: bumpstop bump stop polyurethane poly energy suspension leaf spring travel limiting
#23 ·
Wow FKA thread keep it coming...gonna do this swap or the 2wd box swap (probably the FJ swap)as soon as the snow leaves or I can find a heated garage to hi-jack.:rolleyes:
#25 ·
No word on price for the flat pitman arm?
Is he going to start selling them as one of his regular products?
How is it going to be made? Is he going to machine the center out of a FJ60 arm & weld it into a flat pitman arm?
So would the 2wd pitman arm work? I wish I had a picture of one since it is quite flat.
Boy those FJ60 pitman arms look almost fake or like a welded up booty fab P.A.
LOL!:D
