1 - 20 of 25 Posts
I have a line on a set of Land Cruiser axles for my 87. What would be entailed in the swap other than moving the perches, hybrid driveshaft, and rerouting brake lines. Does anybody know what the strength difference in these are over stock?
Originally posted by tZUKnami:
<STRONG>I have a line on a set of Land Cruiser axles for my 87. What would be entailed in the swap other than moving the perches, hybrid driveshaft, and rerouting brake lines. Does anybody know what the strength difference in these are over stock?</STRONG>
Yuck...birfields..I hate birfields...They are much stronger than stock, but you get birfields and C-clips...you can't get much worse than that..If they have front discs they would prolly be worth the swap, front drums it would be iffy to me. I think they are about 4-6" wider than stock, but I am not sure...
<IMG SRC="smilies/trooper.gif" border="0">
not the way to go I'm told <IMG SRC="smilies/biggrin.gif" border="0"> the only good thing would be the d/shaft lining up.think they are a lot heavier than say toy mini <IMG SRC="smilies/biggrin.gif" border="0">
go with the fj60's at least they're wide. <IMG SRC="smilies/biggrin.gif" border="0"> or you could use toy mini's which would probably be easiest. randys r+p is supposed to have a birf eliminator kit by the end of december for $599. (so i've heard)
<IMG SRC="smilies/rolleyes.gif" border="0">
[ 11-01-2001: Message edited by: poppyseed ]
Originally posted by orangezuk:
<STRONG>
<IMG SRC="smilies/trooper.gif" border="0"></STRONG>
How many Toyota Birfs you broke on your Zuk?
Originally posted by poppyseed:
<STRONG>go with the fj60's at least they're wide. <IMG SRC="smilies/biggrin.gif" border="0"> or you could use toy mini's which would probably be easiest. randys r+p is supposed to have a birf eliminator kit by the end of december for $599. (so i've heard)
[ 11-01-2001: Message edited by: poppyseed ]</STRONG>
599.....you can get a set of waggy axles for that....you dont have birfs there....
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Originally posted by fatkid:
<STRONG>How many Toyota Birfs you broke on your Zuk?</STRONG>
2 Dana 44 front axles...and counting...i steered away from toy axles b/c they were not wide enough and b/c they have birfields. Too many bad experiences with the birfields...a buddy with a minitruck front end in his zuk has broken 3 (i think) birfields - one was a newfield. if you want toy axles you can have them...i want a 60.
<STRONG>i only have about 20 street miles on my setup. <IMG SRC="smilies/blush2.gif" border="0"> i'm happy to report no breakage yet with 38's. <IMG SRC="smilies/thefinger.gif" border="0"></STRONG>
You mean that thing moves???
<STRONG>2 Dana 44 front axles...and counting...i steered away from toy axles b/c they were not wide enough and b/c they have birfields. Too many bad experiences with the birfields...a buddy with a minitruck front end in his zuk has broken 3 (i think) birfields - one was a newfield. if you want toy axles you can have them...i want a 60.
I have em, and they have done well, not to mention they've done well for Toyota's. And your right if you want width 44's can give you that. So did you break the u-joint or the shaft? Cause breaking a axle shaft is a different story, not to mention I think a 44 axle shaft is just about the same size as a Toy front shaft.
<STRONG>I have em, and they have done well, not to mention they've done well for Toyota's. And your right if you want width 44's can give you that. So did you break the u-joint or the shaft? Cause breaking a axle shaft is a different story, not to mention I think a 44 axle shaft is just about the same size as a Toy front shaft.
The first time I broke the ujoint, stub and the inner axle..it was gruesome...the second time I took out the Ujoint which killed the stub shaft.
<STRONG>...not to mention I think a 44 axle shaft is just about the same size as a Toy front shaft.</STRONG>
<font color="yellow">Nope. Not just about. exactly the same size. You can slide a D44 shaft into a toyota carrier.
D44 & Minitruck front have same spine cound & diameter. Only difference is that the D44 has a steeper taper to the shaft... so a D44 fits into a Toy, but not *quite* vice versa.
That's all a birf. eliminator kit is... custom length D44 shafts and a yoke that will fit inside the Toy knuckle.
IMHO, a D44 is a better choice if you don't have any money in the Toy stuff already. But I already have a locked carrier and a bunch of shitzu ready when I take the torch to the IFS. The only reason to go with Toy stuff is if you find a complete donor truck for the drivetrain and already have the axles, or if you get the hook up on a set of 'em.
A D44 and an 8" are theorectically the same strength - IF you ignore the U-joint vs. Birfield part. Only other strength differences are that the D44 housing might be stronger, and the Dana ring gear is 0.5" bigger.
That said, it's cool to be able to blow a gearset out on the trail and have the spare one in and ready to go in 2 hours. Of course... R&P rarely break compared to Birf's.</font>
.</font>[/QB]
You think so, sounds like you went to the dark side.
<IMG SRC="smilies/rolleyes.gif" border="0"> <IMG SRC="smilies/vader1.gif" border="0">
Discussion Starter · #17 ·
I do have a hook up on a set of them. By the way, what is the difference in clearence between the FJ axles and the D44's?
Discussion Starter · #19 ·
How much clearance will I lose from stock axle to FJ40 axle?
I just measured, it hangs 1 1/4" lower. If you go with larger tires you can get your clearance back. Its a reasonable trade-off for the stronger axle. Also, each one weighs about 100lbs more, thats not too bad. We are building my buddies sami up over the winter and I am putting Cruiser axles in mine so I may be gaining 200lbs in axles but his fat a$$ wont be riding with me anymore and he weighs 250lbs. The way I see it, I'm gonna be 50lbs lighter!:D
1 - 20 of 25 Posts
