1 - 17 of 17 Posts
1967 FJ45 LPB (long wheelbase removeable top)
-327 V8 (Corvete motor)
-Camel hump heads
-Ceramic Coated headers
-Carter AFB 4bbl. carb. & aluminum intake
-GM SM420 4 speed transmission
-Stock axles with 4.10 gears
-New Magna flow exhaust
-New marine grade vinyl seats
-Saginaw power steering conversion
-Early 3 speed Land Cruiser transfer case
$7900
Lovingly referred to as the red-headed step child by my wife, this is definately a cool cruiser with a ton of potential and a removeable steel hardtop. I purchased this truck out of a Georgetown, California ranch and had it shipped here to Alabama less than a year ago, feeling the pressure to sell I removed the interior and bed and began cleaning and de-greasing what obviously was a working farm truck, hoping that by the time I re-assembled it that my finances would improve and I would be able to keep it.
I wire wheeled, primed and painted the rear frame with Industrial Rustoleum (including the underside of the bed) I then painted the interior of the bed with Dupli-Color bedliner. I stripped and cleaned the interior floor pans and Herculined the interior floors while the fuel tank was being boiled and lined. I had the seats stripped, the frames painted and new black marine grade vinyl covers them now. The brakes were adjusted all fluids changed and I did my best to clean up a horribly welded transmission hump and re-installed it with new stainless hardware.
There are a few issues with the truck, there is a frame patch on the passenger side spring hanger & the rear rails are clipped at tha last bed tab. There is a floor patch from the SM420 install but it appears to be well done. The title for this vehicle was lost after shipping, I do have scans of the Idaho title from the previous owner and I would gladly assist any new owner in re-titling it if necessary. One of the early Warn hubs is damaged but I never bothered replacing it since I had hoped to install a disc brake axle later on. Somebody cut out the stock gauge cluster and set in a plate of lighted gauges, the gauges do work but I had hoped to re-install a stock cluster and steering wheel since the fabrication work was less than stellar.
This truck starts, runs and drives good and needs little to be a daily driver or wheeler. I found no rot while working on the body and frame rails, it's actually more solid than my 78 Fj40 and would be a great platform for a not so stock restoration.
Jerry Hocutt (205)295-3119 work (205)384-1811 home
Serious inquiries only PLEASE!
1 - 17 of 17 Posts
