I am in dire need a pair of the coil buckets from a FJ80 front axle. This is the pad which the "pigtail" end of the coil spring rests in. Please let me know at [email protected] if you have any ideas.
I need the axle side. See the attached pic.Daveyclimber said:Um , is this the axle side or the frame side ?
Damn, I am in GA. I'll send you a hack saw. LOL Seriously, do you have an air compressor? A die grinder with a cut-off wheel will do it.Daveyclimber said:Where are you located ? I have the fj80 axle , going leaves but no way to cut the mounts off yet
Bumb for help. Anybody able to help Davey cut the mounts off?Daveyclimber said:Where are you located ? I have the fj80 axle , going leaves but no way to cut the mounts off yet
