1 - 20 of 20 Posts
Vendor
Boy are we excited to be releasing these!
Fully Fabricated outer fj80 based knuckles!
Features:
-KEYED High Steer interface, strongest steering ever built for these. All the torque load from steering goes directly from the arm into the knuckle! Add our ARP Knuckle Studs for even more security!
-Rediculously strong, 100% made in USA, machined in house!
-Option for brake upgrade, to bring those heavy cruisers to a halt!
-Stock steering arms mount to the bottom
-ABS COMPATIBLE for all you folks wanting to retain full function of your vehicles safety features!
-Steering arms will be stocked in a "blank" state, so we, or you can drill holes wherever you'd like, for whatever rod ends, even tie into the stock arms!
Pre order list going on now, give us a call to get on that list, shipping expected end of March! All build in house!
Do you have a new knuckle housing or machine the stock housing to fit the arms on?
What's the price on these things?
Vendor
Discussion Starter #7
For the FJ80 its a new fabricated knuckle and Keyed arm as a set, looking at 995
for mini truck knuckles/fj40/fj60, we have Keyed arms starting at 249
Lots of bearing, and steering location options too!
Any pictures installed?? Do with the cross over y link does it make contact with panhard on an 80???
I am extremely interested, just curious about some of the minor details
Sent from my LG-H831 using Tapatalk
Vendor
Discussion Starter #10
Can you use TREs with these arms?
YES! The arms will have the proper angle cut in them, so using tierod ends will be easy!
Vendor
Discussion Starter #11
The arms will be stocked with no holes, so we can locate tierod holes in any configuration. So yes, you have a Y style steering and clear the panhard! We will be releasing basic steering kits (rod ends, links etc) shortly as well!
Very interesting
I know currently anyone who ends up going with a crossover steering using a y link currently hit the panhard
If i wanted to go the 25 mm pin route whats the cost going be?? New lower arms as well??
Vendor
Discussion Starter #13
Very interesting
New lower caps, and all 4 bearings, likely end up the same upgrade cost as our mini truck offering, so 200 for all. We will not be making new lower arms, just caps like you find on bottoms of other Toyota knuckles.
will factory lower steering arms still fit?? I know myself A can still run my rear hydro assist ram than with ease out of harms way as im still running my factory suspension arms, B double sheer High steer up front sounds a amazing ;) C the guys who will just want the brake upgrade will probably be happy to hear it
remember the 80's dont run lower caps they run steering off them, and LOTS of guys in particular will want the ability to just increase braking power ;)
I know myself, my newly added power from the LS and the hydroboost brake setup could lead to some amazing braking power
Vendor
Discussion Starter #17
Yes factory lower arms still fit, and yes you could run double sheer with that!
Yes we can do just a brake upgrade, and reuse the rest of the factory components, for those less "extreme" builds :)
Expect an order from me in the spring :D
Unfortunately all my extra cash goes towards my ls conversion ;)
Brian, can u post up pics of this new knuckle with all the compatible brake options installed excluding fj80 brakes since most of us already know what they look like. And we need more pics. That single teaser pic just isn't enough for us! Thanks
1 - 20 of 20 Posts
