1 - 1 of 1 Posts
SoCal
FRONT:
Passenger Drop, 8" High Pinion 4.10 geared NON LOCKER. Large disc brakes, huge birfields and axle shafts compared with the pickup size, and all around a really strong factory axle. Standard 6 x 5.5 bolt pattern
$550 including brakes, drag link and tie rod, and even the lug nuts. Still in the car. Car will be on Jackstands. You will be pulling it. NO shipping. You can have the lower control arms too!
I am not parting this axle out. If you need front parts, I also have the following:
Hubs, Spindles, Axle Shafts, rotors, calipers, axle housing, driver knuckle, and one birfield. IF you want to twist my arm, the front high pinion third member is $300 firm, you pull. I would rather keep axle together.
AVAILABLE IF YOU ARE DOING AN SAS CONVESION ARE THE FACTORY FJ80 COIL BUCKETS
REAR:
Rear Axle 9.5 ring and Pinion Full Float with Disk Brakes, NON LOCKER. $500.
1 - 1 of 1 Posts
