from what I read in the fine print of the website is that these are for "hotrods" ie non-computer controlled.
what do the actual instructions on
yours say...ie what yr/models/ etc
eg. computer controlled or not?
ie...if you start sending raw fuel through
the exhaust then all sorts of faults are going to be seen by any computer controlled ECM/PCM/ECU vehicle starting
with the O2 sensors telling the PCM that all hell is breaking loose and start setting Fault codes.
Thats not even considering what the raw fuel will do to the CATS
I'm interested but only if it doesn't screw the system up.
thanks
