21 - 34 of 34 Posts
stopped by my local napa, who provided the following cross-reference info:
Bendix = 77700
Aimco = 8917673
Wagner = BH119389
Raybestos = BH38878
Carquest = SP7024
I am getting closer...
manny
PS.
Brian,
SWEET buggy project :D
And the winner for the illusive UP338878 is (vehicle application):
1989 TOYOTA VAN WAGON L4 2.2 Liter FI
Rear Hose: 2WD; Standard; Disc
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESULTS&MfrCode=RAY&MfrPartNumber=BH38878&PartType=228&PTSet=A
I sent russell and earl's an email to see If they offer a replacement...but they may not reply until after the holidays.
Contact Earl's Tech Service:
(310) 609-1602
russell Technical Support: 1-800-416-8628
1-310-781-2222
forget-it, I'm going to make my own lines w/following part#s
caliper end/adapter
EAR-592032ERL
Fitting, Brake, Steel, Zinc Plated, Male -3 AN to Male 10mm. x 1.0 Thread,
Pair $11.69
hard-line connector/adapter to braided line
EAR-989545ERL
Fitting, Brake, Steel, Zinc Plated, Male -3 AN to Female 10mm. x 1.0 Thread,
each $4.69
straight to straight in 12"
EAR-63010112ERL
Hose, Speed-Flex,-3AN Str to -3AN Str 12" Long, Teflon Lined, Assembled
each $9.88
thanks again for input,
manny
1-310-781-2222
manny
My Lines are Russell line's, I dont think there is a part#. I can find out though. :D
Manny and Rockhugger if either of you find a premade Earls or Russell braided line the same specs as the van wagon please post the part number as I think I may want to purchase a set. Thanks
OK, I finished my new bling today...vented disc brakes :D
I took some measurements and It appears that with a 90 at the caliper, I could use a 10" line to the existing bracket on the axle (see Rockhugger's pic).
A 12" line would give additional room for removing the caliper when necessary.
Rockhugger,
Do you remember the length of your Russell lines?
thanks,
manny
Rockhugger,
thanks,
manny
I will have to measure, I can't remember how long they are :D
Rolling Mod
I just so happen to have it here at the house, but no tape measure.
I'd estimate 12" oal. Female end 10mmx1.0 Inverted flare., Male end 10mmx1.0 inverted flare.
I'll confirm the length tommorow. Also Polyperformance sells the universal brakeline components.
Here are 2 pics of my setup using the Napa 38878 flex lines that we finished yesterday!
Huge thanks to cruiserbrett for the help and idea of this mounting method! I think it looks super clean and functional!
Rolling Mod
11.5" OAL. All else is correct.
Earl's said NO, have not heard from Russell yet.
Dear Manny,
We do not have a break hose for your vehicle. Although we do offer
parts to make your own braided line kit. The do it your self kits, are NOT
D.O.T. approved.
Chris Wiesinger
Edelbrock Corporation Tech Department
I ordered the D.O.T. approved pre-made 12" 3AN straight-to-straight w/metric adapters (part# from prevous post).
total $45.00
thanks everyone for your input,
manny
Rolling Mod
If you use a Russell DOT legal #3 universal hose assembly (I do not know if Earls makes one) then you are DOT compliant. The adapters do not effect the DOT compliance, only the crimp collar style.
21 - 34 of 34 Posts
