1 - 4 of 4 Posts
Can anyone tell me if you have 2 different size U bolts on your flip kit.Have just made a flip kit and gone to mount it and the outer side of the spring perch is at least 10mm / 3/8 thinner than the pumkin side part of the spring perch.
Thanks Rhino
we are using a 75mm / 3 inch U bolt on the innner part of the spring perch
On toyota's the front pearches are different sizes. the one on the pumpkin side is slighty higher than the other one. Some people put a spacer on the lower side to make the springs ride at the same hight, and others have different springs with different sring rates to make up the difference (such as the stock springs).
My filp kit came with 1 u-bolt that was longer than the other (that one goes closest to the pumpkin).
just bolt it on and go wheeling. <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0">
1 - 4 of 4 Posts
