What oils do I run in my 3 spped case d20 and f&r end Thanx CHUCK
T Tonka_sam · Registered Joined May 12, 2000 · 78 Posts Discussion Starter · #1 · Oct 1, 2001 Only show this user What oils do I run in my 3 spped case d20 and f&r end Thanx CHUCK
H hy_desert_4wheeler · Registered Joined Jan 12, 2001 · 1,857 Posts #2 · Oct 9, 2001 Only show this user they should all use 90wt
J jigggawatt · Registered Joined Jul 31, 2000 · 15 Posts #3 · Oct 9, 2001 Only show this user they dana 20 uses 50wt motor oil,but I run syn. 80wt. gear oil with no problem
T Tonka_sam · Registered Joined May 12, 2000 · 78 Posts Discussion Starter · #4 · Oct 9, 2001 Only show this user Thanx I just put 90w front to back then I found out that my d20 front shaft leaks like a pig
