1 - 6 of 6 Posts
Hey guys
I am about to upgrade my junk alternator in my 1990 YJ with the 2.5L to a Powermaster 140amp unit (what are the opinions of these bad boys)?
I am planning on upgrading the alternator to run a power inverter for when i go camping and such. I was thinking of the Coleman 1000watt version.
I was wondering what others are running and what alternator they are using and what kind of appliances they are running?
Thanks
Stock XJ alt and I have a Vector 750 Watt inverter. So far it's mainly done :blender: duty but has run a 4" angle grinder as well.
Jes
I have been using a Powermaster 140 amp alt for a couple of years now and had no problems.
Its a 1 wire alt and you have to blip the throttle when the engine first starts to get the alt to charge (excite the field).
The alt had a tag attached to it that said that the alt was capable of 160 amps at 3000 rpm.
I have two yellow tops, winch, compressor, sterio, and spot lights. I use a Coleman 1400 watt inverter for any AC requirements.
With the optimas, high output alt, and all the accessories on, I can winch and still not zap the batteries.
I like it!
I like it!
Awesome! That is the info i needed!
Minus the dual batteries, that is the setup i plan on
Thanks
1 - 6 of 6 Posts
