1 - 2 of 2 Posts
For sale is a 4 door extended cab 4 wheel drive ford SVT Raptor. The body and frame have around 86,500 miles. The drive train has around 1,000 miles. Located in Avon Indiana, 46122. Truck is a Arizona truck originally, so no rust what so ever on it. I can help/ arrange shipping to the lower 48 if needed. It costs roughly $1400 to ship a vehicle and it can be delivered within 6 days. $55,000 OBO. text or call 9255846702
Engine/Transmission/ Transfer case
-New OEM Ford 6.2 liter crate motor, has a 3 year unlimited mile warranty good at any Ford dealership. Warranty good until April of 2023.
-New OEM intake manifold
-New OEM fuel injectors
-New OEM electric fans
-New OEM serpentine belt
-New OEM battery tray/ windshield wiper fluid tank
-Oversized throttle body
-K&N cold air intake kit
-Valve covers are painted with steel it black
-SCT handheld tuner. (Current tune is set up to run 91 octane)
-Mishimoto oversize radiator. The tranny cooler was removed from the radiator for more coolant capacity and higher flow.
-Custom aluminum blue anodized coolant/ heater lines with Mishimoto rubber hose ends and clamps
-Stainless steel headers and full stainless steel exhaust system
-Mishimoto universal oil cooler. With BMRS -10 lines (engine oil cooler) does not go through the lower radiator hose anymore.
-Lokar flexible oil dip stick for engine
-Bran new 6R80 transmission built by power by the hour. Upgraded billet internals. Upgraded clutch discs, etc. Able to handle 1000 plus HP. Painted with steel it gray
-Circle D billet torque convertor
-CBR transmission/power steering cooler with electric fan. Has BMRS -8 hoses that connect to transmission and to power steering.
-Transfer case was rebuild and painted with steel it gray
-SDHQ battery terminal kit
-JLT PCV valve oil catch can, mounted on passenger side
- Front and rear drive shaft are painted with steel it gray
-Frame/skid plate/ trans cross member painted with steel it black
-New OEM cv shafts passenger and driver side
-RCV IWE eliminator kit. (got rid of all the vacuum line)
-Brakes are all in like new shape, has second set of calipers mounted on the rear to run a hand brake in the cab. (hand brake is not installed)
Exterior
-Advanced fiberglass front fenders with wheel well liners
-Recon projector headlights
-LEX off road fabricated front bumper and skid plate
-LCA slots welded up
-Full ICON mid travel suspension system. Coil overs with extended reservoir on the front with billet upper control arms, rear has triple bypass shocks with deaver leaf springs
-Beefed up OEM spindles. (welded steel plates/ gussets on them)
-Upgraded solid billet tie rods with high misalignment heims
-LEX off road rear fabricated bumper
-Dual Viair air compressors with 2.5 gallon tank mounted where spare tire would go
-LEX off road bed mounted chase rack. Holds 2 35” tires, 3 5 gallon fuel jugs, ice chest, pelican case, ammo cans
-Paint has some scratches and rock chips
-(4) Nitto A/T terra grappler G2 35x12.5x17 wheel. 80% tread left. (on truck currently)
-(6) Method real bead lock race wheels black. (1) is not a real bead lock
-(2) General Grabber 35x12.5x17 50% tread left
-20% window tint all the way around except windshield
Interior
-LEX off road full interior roll cage. 1.750x.120 wall Chromoly. Cage is mounted to the frame on body mount bushings. So cage can move with the body.
-(3) Corbeau racing seats with 5 point Corbeau harness. The seats and harness are all tied into the roll cage
-The head liner, steering wheel, center console, and dash have all been re wrapped in suede
-Has a custom baby car seat platform welded to the roll cage to bring your child along
-Lowrance touchscreen GPS HDS7m
1 - 2 of 2 Posts
