1 - 7 of 7 Posts
I have swapped a 350tbi, T18, Dana300 (4:1) in my CJ7 and I havent tackled the issue of the tranny mount yet.
Would a similar setup to the one below work well to control the amount of torque my drivetrain will produce or do I need to incorporate some type of torque arm?
See the pic here (100k).... http://www.users.qwest.net/~jeeperaz/tmount.jpg
Any thoughts or opinions are welcome!
[ 10-21-2001: Message edited by: DesertJeeper ]
That mount doesn't appear to have any dampening parts on it. I'd think you'd want
some shock/insulating characteristics to keep
from breaking parts.
Even seen how strong a motor can be running
near 100-to-1 considering torque? I'm amazed
most stock motor mounts don't serperate more
often.
I'd put some sort of dampner in there. But
it is a very clean application..
--Sherpa
The only thing I don't like about it is that there is no rubber in the mount. I think that a poly bushing or a simple flat piece of poly or rubber on the mounting surface would really make it a lot nicer.
Thinking about it, I'm also not real sure if I like the idea of having the mount pad hinged to the x-member. To me that seems to be a situation where the tranny could move it self arond.
Originally posted by DUG:
[QB]The only thing I don't like about it is that there is no rubber in the mount. I think that a poly bushing or a simple flat piece of poly or rubber on the mounting surface would really make it a lot nicer.
QB]
It looks like it probably does have rubber in it, Where the long single bolt goes through the tube, where the tranny mount and crossmember meet, It probably has a poly or rubber bushing. Just what it looks like to me. <IMG SRC="smilies/biggrin.gif" border="0">
the mount looks super clean and compact, i like it. like you said i would also poly mont it to the frame. this one doesn't seem to removal friendly.
[ 10-21-2001: Message edited by: it'll fit ]
1 - 7 of 7 Posts
