1 - 20 of 34 Posts
I am swapping out the Dana 35 for a Ford 8.8 with 4.10 gears and a factory Limited slip??? What is any ones take on the Limited slip in this axle, Should start looking for a locker, If so what locker is best in the 8.8. I had a Lock rite and I liked it in the Dana 35, to bad the dana 35 is junk.
Thanks In Advance
Its a loaded question ..The 8.8 is a great swap.But you need to weld the tubes or some guys are bolting them I have heard...your choice on the locker if your going cheap like me try the aussie...this is my opinion I am sure others will disagree...good luck
You should replace the whole thing with a full case locker of some sort like a Detroit or ARB. I have heard that the carrier is the weak point of the axle. Also, like stated earlier, have someone weld the tubes to the housing to keep them from spinning.
I have heard this also ...scratch the lunchbox idea..
I wouldn't bother with a limited slip. They are generally more "slip" than "limited".
Get a lunchbox if you're not afraid of breaking your stock 8.8 carrier, or get a full locker to replace it all.
I saw in JP magazine they just released an OX locker for 8.8 ...
The ford trash-locs are trash. Plenty of guys run lunchboxes on 8.8s, haven't heard much in the way of breakage but it does happen. Detroit/ARB if you want it strong as possible, Powertrax No-Slip for the LS carrier if you want to keep it simple...
I'll go against the flow with the majority of guys here.. While a full locker is the best route, if you are on a budget, and you don't mind finessing through your wheeling a little bit, a factory trac loc is fine, especially if you have a front locker. I run a front lock right and an 8.8 rear with a trac lock, and its never stopped me from wheelin. I have had to do a little finessing of the brake pedal in certain situations to get the trac lock to lock up, but other than that, I like it. I am a cheap bastard though, so YMMMV. I was thinking of welding up the mini spiders in the tracloc for a "spool", but I haven't decided if thats a good idea yet or not.
Scott
I have the trac lok in my 8.8 and it has done just fine. But if I were to replace it (and I have thought hard about it) I would replace it with a unit that replaces the entire carrier.
From what research I have done, if you want to go to a locker, you will have to get a carrier from a non trac lok axle anyways. Why not just replace the entire unit with a locker?
Except for the Powertrax No-Slip I listed a couple posts ago, there is a model for the 8.8 LS carrier, which is why I listed it as the easy route but not the strongest.
Weld the tubes to the center. Install a Detroit. Build or buy a beefy diff cover, the 8.8 covers are made of tin foil. Build it right the first time. When I ordered my gears from randy's ring and pinion the guy on the phone recommended a full case locker for the 8.8, he said the carrier is the weakest point on that axle.
1998 TJ with stuff
Weld small sections at a time as you don't want to get axle tubes too hot :eek: I have the full Detroit in my 8.8 and wouldn't have it any other way. I have the Aussie up front, it's tough as nails.
That's the problem, everyone has "heard" that. It's not like a D35, where everyone has actually seen a broken D35, several in most of our cases. I call bullshit on the weak 8.8 carrier. Sure it can be broken, just like anything else, but it's not "weak". The Dana 35 is "weak".
I have an Aussie in my 8.8. My carrier is just fine.
Good info. I haven't really looked into it since I stuck the 8.8 into my YJ a couple of years ago...
Thanks In Advance
Just from my experience, DON'T go with an Eaton e-locker. The damn thing won't lock at all now, less than two years old. Ball ramps are chewed. And I know NOT to engage while driving!!
I'm swapping an 8.8 into my TJ as we speak. I am going with a Detroit, 4.56's and Yukon shafts. I would recommend saving up for a full case locker like suggested earlier. I did and I won't be afraid to romp on it when I'm wheeling. If you have any questions on your swap let me know.
1 - 20 of 34 Posts
