please help, trying to find disc brake that will fit over outer axle flange on ford 9" rear-end. Do not like B.C. broncos version where disc hat is on inside. Any info would be greatly appreciated.
I got explorer rotors (and brakes) on my semi-float 60 (same as small bearing 9"). I think that is pretty common.:smokin:please help, trying to find disc brake that will fit over outer axle flange on ford 9" rear-end. Do not like B.C. broncos version where disc hat is on inside. Any info would be greatly appreciated.
Out of curiosity do you know the measurement across the inside diameter of the hat part on these rotors? Looking for about 7.5".I got explorer rotors (and brakes) on my semi-float 60 (same as small bearing 9"). I think that is pretty common.:smokin:
Am I missing something here?You are taking about the flange on the end of the shaft right?
Why not cut down the OD of the flange a little so the rotor will fit. Take it to a machine shop or get a buddy to spin it while you hit it with a grinder.
Nope, I'm just starting to gather parts for my front/rear disk swap on a set of 44/9" axles from a '74 F100. I've bought Chevy front caliper mounts for the 44 and a set of weld on mounts for the 9". I haven't gotten around to buying rotors yet.Do you know the answer to my original question?
