1 - 2 of 2 Posts
Was given a ford d20 and noticed its drivers drop.
Anyone know if the bolt pattern under the addapter
is the same as a jeep d20??
I have found twin stick and gears for it as well.
Thinking of using it in my project tj.
:confused:
Won't bolt up. You'll need an adapter and stub shaft. Since you an adpater, Klune, Blackbox, and the like can be the adapter as well as the extra low gear for a doubler setup. Next, you'll have to configure an electronic speedo since your TJ's computer runs one, unless you are not running stock engine.
1 - 2 of 2 Posts
