1 - 3 of 3 Posts
I am planing on swaping a 351 and a NP 435 in to my 71 FJ-40. i already have the AA crossmember for the t-case but i neede some info on motor mounts, instalation and all the other things i need to get this swap done. Is there a sight that has info on Ford swaps? I ckecked woodys sight and all the info there is for Chevy swaps. Thanks for your help.
Michael
The Ford swap is not a common one. I think I have only seen one Cruzah with a Ford engine in it. Unfortunately the only info I have come across on this adventure would be advanced adapters. <IMG SRC="smilies/skull.gif" border="0">
Discount!
My motor mounts are prety simple, just a round'ish shaped triangle plate thats bolts to the block, then rubber cushions between that and the plates welded to the frame rails.
You will also need the AA adpater kit with new NP435 main shaft. (thats alot of fun!)
But you'll love the SB Ford under the hood!
Jeff
1 - 3 of 3 Posts
