1 - 10 of 10 Posts
my pump was spittin all day yesterday playin in the rocks and I had to manhandle the steering - any bolt on suggestions for a serpentine 5.0?
Maybe a cooler or ?
posted a couple picks in the membas section and the toy section <IMG SRC="smilies/smile.gif" border="0">
pics suck though - so back to the pump, not sure if it is just a cooling issue but it sure didn't work most of the time..
Supposedly the 5.0 Van's used a Saginaw pump, and the bracket is almost if not completely bolt on. You will definatley need a cooler though.
Hell I used to have to run a cooler and a catch can on my Road race car, with little (by wheeler standards) tires.
But the Saginaw is supposed to be THE answer.
ford trw pumps suck, end of story. i dont know if your 5.0 brackets are the same as my 5.8 but the only solution i could think up was ditch that bracket and fab one to hold a sagnaw pump using a chevy six rib pully. this was way to much work for me considering it also mounts my supercharger so i deal with it. i run my arb off as much as posible to ease the strain.
Yup, i did this converson on many full size bronco with 5.0s should be the same,
you need the bracket and pump and pully from a 89 (thinking) or newer Van, you also would need to change your high pSi line fitting, other then changine the line its a bolt on
Discussion Starter · #9 ·
okey dokey, I'll go hunting <IMG SRC="smilies/smile.gif" border="0">
I got an Earls hose so I can just get a new fitting for the end, shouldn't be a big deal there.
1 - 10 of 10 Posts
