I'm having some pretty weird issues with my TTB under my '87 F150. I bought the truck off of some ******* who apparently jumped it and then wanted to sell it. Me, being an idiot, bought it anyway because I was hoping for a good project to work on. I got more than I bargained for!
I noticed that the lift kit that was put under it is a custom fabricated job. A job that wasn't done thoroughly and properly. The drop radius arm brackets are fabricated through some rectangular stock that's 3" wide and about 5" tall. One bracket seems to be level with the frame and the other is crooked. The guy that installed the lift welded the brackets to the frame and used what looks like grade 8 hardware as well. The pivot arm brackets are done in the same fashion (welded and bolted).
I am hearing a clunking/popping noise when the truck hits a quick bump (i.e. a dirt road washout or pulling the front end off of a curb). Normal driving doesn't make the popping noises. I've checked all of the rivets that hold the bracketry to the frame and none seem to be loose. I also jacked up the front of the truck and dropped it numerous amounts of times to see if I could get the popping noise to happen. No go there, no movement in any of the brackets or anything like that. I'm wondering if any of you Ford guru's on this site have any insight to this problem.
I have replaced the upper and lower balljoints (about 500 miles on them now), replaced the top-hat style hubs with a conversion to the rotor-styled ones. I've replaced the radius arm bushings. I've replaced the pivot arm bushings (man is that a bitch!).
I don't have the cash flow to perform a SAS, and I'd like to think that this is a fixable issue. Any of you know what to check next?
