1 - 5 of 5 Posts
I am a Jeep guy who is putting EB axles, transmission and T-case and a F150 engine in my Jeep. I was going to put in a thunderbird 5.0, but that deal fell out.
Is a 1989 F150 5.0L 4x4 Auto Mass air? If not, what do I need to do to make it Mass Air? I havent even checked the engine out yet, but what should I look for?
TIA,
Stowe
1st are you sure the 5 150 intakes will clear, they are much taller than the car intakes. second why bother putting the mass air system on it, speed density works fine unless you are going to modify the engine. also if you are using the wireing and comp from the f150 then you would have bank fire, which again isnt bad, but why change something that works. stick a speed density upper and lower and thottle body on it and go with it. you already have what you need and it will work just fine.
1 - 5 of 5 Posts
