1 - 20 of 22 Posts
You read it right. I have MOST of the parts to complete a Formula Toy. I have been assigned the task to unload this unfinished project. Due to the potential probate I must liquidate the assets in a timly fashion. This is add is for EVERYTHING at one price. I do not want to part this out so please don't ask.
Price Reduction: $9500
Details:
Ron Davis Radiator with fan/shroud
-With Transmission cooler
-Double Pass
-Specifically made for a Formula Toy Chassis
Panels
-Alloy floors
-Alloy Trans Hump
-Ally roof
-Alloy firewall
Champion Beadlock (one wheel)
-8.5 x 17” w 4.5” backspacing
-Cast wheel
Interco Truxis Sticky Tires
-4 Tires
-Used 50%
-37x12.5x17
PRP Seat
-Top of the line model
-Removable Cushion
-Pro Comp Seat?
-New and never used but dirty from laying around
-Seat brackets were removed and need to be replaced
PRP Seat
-Non Removable Cushion
-Slightly modified as a passenger seat to fit over the transfer case hump in a formula toy
Inch Worm Transfer Case 5.0
-300m output shaft
-Twin stick
Diamond Axles
-5.27 gear ratio with Cryo’d gears
-Long Field shafts with Long Field Birfs
-Comes with Drive flanges AND locking hubs
-Brake rotors, calipers, drums, pads, studs, etc. ALL NEW
-Leaf perches included but not welded on
-New and never used
-High Steer arms from Diamond with steering drag link and tie rod INCLUDED
Deaver Formula Toy leaf packs
-For complete vehicle (front and rear)
-Included Baja Joints (orbital type) in rear leaf pack (rubber in front)
-Specially tuned for Formula Toy
Formula Toy Chassis
-Hendrix Chassis #79
-DOM tubing
-Toyota frame is an early pick-up frame
-Has ALL holes welded up (an older solid axle frame)
-Frame will need to be connected to the chassis
-No rust
-Includes Adjustable steering bracket (not installed but pictured)
Toyota 22 RE engine
-Manifolds blocked off and converted
-New water pump
-New Pullies and belts
-PSC Power Steering Pump (high volume) w reservoir and mounting brackets
-Powermate by Wrangler High output single wire alternator 110 AMP
-Crank Fire ignition and fuel injection
-Includes 4WD oil pan
-LC Engineering header for Formula Toy
-Ceramic coated with gasket
-Simple Digital Systems computer and ignition w/ LCD Ignition Programmer AND harness Worth $1400!
-Bosch High pressure Injection Pump
-Intake Manifolds and other parts included to make it complete
Rancho Shocks
-RS9000 Shocks
-15” of Travel
-Adjustable valving
-Ultra fast White with red bushings
Bump Stop Clamps
-4 included
Warn 1700 Winch (Warn Competition Winch Not included)
-New and never used
-With Wired controller
Trail Gear Steering Box
-Ported for Hydro Assist
-Included PSC 8” Ram
-Pitman Arm included
Blinging Gold Shackles
-For the front of an F-Toy
-Zirc Fitting bolts included
Traction bar and rear engine cross member for a Formula Toy.
-Rod ends and bushings included
-Mounts to Transfer Case
$11000 Takes it ALL!!!
PM me for more details or inquiries.
Price reduction to 10K!!!!
The axles alone (which are NEW) are 8K. For not much more you get tons more.
Really wish I had the cash!! Regret building my 1 ton wrangler cause now I need a tow rig. With an f-toy it would be so much easier to pull around---------------Kyle
Discussion Starter · #12 ·
Would love the SDS system....If you part that is.....
Maybe in time.
I find it hard to beleive that this hasn't gone. Axles and chassis cost the same as what I have reduced the price to be.
Damn economy.......:shaking:
Discussion Starter · #13 ·
Bump
I am pretty close to parting this out if it does not go soon.............
The price is $9000 obo
Discussion Starter · #18 · (Edited)
FINAL DEAL
I want this thing GONE for the price of the axles are new (keep in mind the axles ARE 100% new and never used).
$8200 for the axles and EVERYTHING ELSE comes with it.
Must be gone in a week.
1 - 20 of 22 Posts
