1 - 3 of 3 Posts
I am going to install my pitman arm insert tomarrow and need to know the details on installing it.
Thanks, later,
Wicked Raciest !
Originally posted by TANKOMA:
<STRONG>I am going to install my pitman arm insert tomarrow and need to know the details on installing it.
Thanks, later,</STRONG>
Press it in!!! Just make sure it goes in straight. If you do not have access to a press use a vice with soft jaw inserts.
<IMG SRC="smilies/rolleyes.gif" border="0"> <IMG SRC="smilies/rolleyes.gif" border="0">
[ 08-15-2001: Message edited by: OPP'S ]
Be forewarned, if you don't have an original Toyota pitman arm, it won't fit w/o some modification.
Basically just grind the edges of the cap off, pop out the ball stud and other junk, and press in the insert. <IMG SRC="smilies/smile.gif" border="0">
Actually, Eight said he just pressed the stud right out w/o even grinding the cap first, so if you have a press, you can try that first too.
1 - 3 of 3 Posts
