1 - 10 of 10 Posts
I created these for my Ibex DIY chassis kits but will work great on almost any front axle that you need to mount a double ended ram to. They are a great solution to a Dana 60 or 44 with a removable cover, but also work well on a fabricated 9" type housing.
Available in two different axle tube sizes, 3-1/8 that fits most OEM Dana 60's and 3-1/2 to fit late model Dana 60's and aftermarket Ford 9" type housings. Also available in left hand and right hand diff drop. Fit's most manufacturer's steering rams with flat weld on mounting clamps.
PM, Email, [email protected], or call 262-295-8599 to order
  • $119.95 WEB LINK
  • Superior by design and constructed of high strength 3/16 XT 100 grade steel. At 100,000 psi yield strength, these brackets are 3 times stronger than the mild steel other bracket manufactures use
  • Variable ram height location, mount can be rotated for higher or lower mounting location.
  • Removable skid plate protects the ram from rocks
  • Includes tabs for a suck down winch attachment point.
Very nice quality. I'm about to install this on a customer's buggy. The price with the high strength material couldn't be beat from anywhere else that I could find.
1 - 10 of 10 Posts
