Front axle question??
622 Views 4 Replies 5 Participants Last post by  SeaBass44
My front axle is alittle loose. You can gab the tire and pull on it and it will make like a clanky noise inside evry time you pull on it. Is this mean I have bad bearings? Or is it something else? I run 38's and i get a little wobble every once in a while. I asume it is from the tires rattling. Should I be going through front bearings alot and is it bad to drive on it. Should I swap in a front d44? Your help would be appricated. Thanks:confused:
1 - 5 of 5 Posts
i would not drive it. take it apart. figure it out. if u have 38`s, you should be going into and checking those wheels oftn. do not put a 44 under it. stay toyota.
sounds like worn out knuckle bearings....get the All Pro kit and have fun...
PS: BUY THE STUD KIT ALSO....helps when bolting all the parts together with 1 hand........
I would 44 it myself........:D :D
finder_87 said:
My front axle is alittle loose. You can gab the tire and pull on it and it will make like a clanky noise inside evry time you pull on it. .........
??????? loose side to side wheel bearing. loose up/down knuckle bearing., if side/side the whel bearing might just be loose, tear it down and check it out.
1 - 5 of 5 Posts
